Hello, this is my gaming rig that I have come up with. The parts will not be purchased soon, i wish, but yeah. I'm looking to play Call of Duty and Grand Theft Auto. Please let me know if anything seems to be bad quality or anything.
Also, I want to record the gameplay, so let me know! Thanks.
if you want to record game play you should record to a second hard drive but to do it and still have a "gaming pc" you will need to up you buget by $50
this is the $550 build. http://pcpartpicker.com/p/sQZa with a better cpu psu and gpu the 660 is cheaper and will beat the 560 ti also the fx 630 is better than the i3 and it also overclocks
I'm pretty sure the 7850 is a pretty good amount faster than a 560 ti, and it's got 2Gb Vram which is better for high res.
The i3 is faster for normal tasks but for gaming a quad core will be alot better and it just overall doesn't matter as much. And later on you can OC and throw on a cooler it can OC pretty well too. The G.skill is a little cheaper and I just like G.skill more.
also am3+ will be gitting another cpu release that will be 15-20% faster (about 7-12% ipc incress and higher stock clock from what we saw with bulldozer to piledriver) and socket 1155 is dead so next year you will have to get a new cpu mb to upgrade. (you could just go to i7 but still it will cost more in the long run)
UPDATE: I may be able to expand my budget up to $600-650. Maybe even $700. I don't want AMD, so any builds that are intel in this price range would be great. Thanks.
For that price range, AMD is the way to go. It will be a really poor build with intel. The intel i3 isnt as good as a 6300, 8350... even a A10 5800 for the price. 1155 mobos are generally more expensive as well. Here is my intel build for 700 dollars, it lacks HDD space, case is medicore, mobo is okay, could use a bigger psu.
Thats a pretty nice build. If you live near a Microcenter theres a deal on the 2500k and 3570k (and you can get $40 off motherboard) which would put you with some more money for a 7870.
Haha CC. That's exaclty what I was thinking. I do live about 45 minutes away from a microcenter, and my dad works right next door, so I am going to check out their prices this friday. Thanks for the reply.
Akira, thanks for the suggestion. I am thinking about going AMD actually. I could save alot of money, and later on, I could change to an i5 right? Just switch out the motherboard and cpu? Thanks. Oh, BTW, how do i get 150$ of free games?
The comment that a 8350 is better in gaming then a 2500k peaked my interest so i did some searching for information on that, here is what i found.
http://www.anandtech.com/bench/Product/697?vs=288 Scroll to the bottom for the gaming benchmarks, at stock clocks the 2500k is anywhere from 10-25+ fps better in gaming then the 8350. I am looking for any benchmarks or information on a 8350 beating a 2500k clock for clock in gaming, if you find it post it here please.
You get 150$ worth of free games by buying a 7900 series graphics card.
get an i5, some games tend to do weird stuff with dual cores (bf3 for example...some glitch or whatever). yea, go for the 660ti, better bang for the buck and less powerconsumption. and up your psu to about 550 watt or something in that direction. it'll give you better power efficiency.
