http://pcpartpicker.com/p/ERJS What do you think
save some money on you thermal paste http://www.amazon.com/Arctic-Cooling-MX-4-Thermal-Compound/dp/B0045JCFLY/ref=sr_1_1?ie=UTF8&qid=1361492173&sr=8-1&keywords=mx4
Not suggesting, just throwing this out there.
(CAS 8) $75 G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory http://pcpartpicker.com/part/gskill-memory-f314900cl8d8gbxm
(it's $1 less!) $125 SeaSonic 750W 80 PLUS Gold Certified ATX12V / EPS12V Power Supply http://pcpartpicker.com/part/seasonic-power-supply-ss750km
(should there be a SSD if you're streaming/gaming? Just curious if SSD performs well when the a demand is "Gaming/Streaming" assuming there's recording going to the hard drive or caching or something.)
http://pcpartpicker.com/p/F7fz
nope. streaming goes straight out.
the build looks pretty good. consider going with an AMD vidcard, if you don't use adobe. maybe a caviar black.
I am thinking of downgrading to a 660ti. Also I am going to be using adobe.
