Gaming PC for 700$ or less
Hi,
I want to build a gaming PC, though I'm more of a console gamer so I need advice. I would spend 700$ for it if I need to, but I know that most games I want to play are not that much hard to run, so if I can spend less then that would be awesome. I did a PcPartPicker, though I'm not sure if it all makes sense so feel free to correct me and suggest other parts. http://ca.pcpartpicker.com/p/1NoGc
Now here's the list of games I'm going to play:
  • Castlevania: Lords of Shadow
  • Dark Souls
  • Devil May Cry 4
  • DiRT 3
  • DmC: Devil May Cry
  • GRID 2
  • Might & Magic Heroes VI: Shades of Darkness
  • Super Street Fighter 4: Arcade Edition
  • Tomb Raider
So I want to play those games in 1080p, 60fps with graphics maxed out. Btw, no need to mention that Dark Souls is locked at 30fps. I will probably play some FPS too but this is less important for me. So if I can play recent FPS with decent graphics and at least 30fps, I would be happy. I want to stay in the HD 7000 series for the video card so I can try that famous Mantle API when it'll be released.
Thank you for your time.
http://ca.pcpartpicker.com/p/1NvNI
If you Oc the 7950 you should be able to get 60 fps pretty much all the time with tomb raider on max+ tressfx.
You can also oc the 8320 with that cooler and mobo if you want to do that later.
Btw. you can use the DSfix mod for darksouls to unlock the fps and resolution, it will drop under 60 fps sometimes though because the port is wonky.
This here except the LE board has had sound card issues.
