Hi everybody.
I would like to build a gaming PC using used parts to lower the cost. The final build should be around 1000 ish euros but as i am buying used, the actual price of the same parts new is not super relevant. I will use this machine mostly for gaming, and day to day use (watching videos, browsing, nothing fancy)
As of now these are the parts i think i will use (http://de.pcpartpicker.com/p/r2qWTW)
I'll add any cheap 8-16 GB ram kit i find
I have doubts about the PSU. Is that wattage overkill? Should i maybe buy the PSU new to avoid problems? What brands/ models can you recommand?
About the motherboard do you have any idea of other boards around 200 euros new that would fit? (I will be overclocking, i am thinking of crossfire in a few years and i might need RAID 0 but i think most higher end boards do that.)
For the storage am i better off grabbing many SSDs and having like one for the OS, one for steam etc + an old HDD i will grab out of my old system or should i just buy one larger SSD and a SSHD for whatever program doesn't fit on the SSD ?
I will also need a screen, preferably IPS, 24 to 27" (haven't made up my mind yet) and 1080 to 1440p. Preferably in the 200-250 euro price range.
Finally i have a Win8 license for a laptop i bought (lenovo yoga 2 pro) but that is now running linux. Can i reuse this key or is it somehow locked to the laptop?
Thank you for your time
