Hello,
I'm going to be building my 1st PC which I will be using for gaming. I'm going to be playing Battlefield 3 primarily, as well as CS:GO, Planetside 2 and most likely Battlefield 4 when that comes out, all at 1080p.
My Budget is around £600.
These are the parts I am considering:
http://uk.pcpartpicker.com/user/KingKevin/saved/1RXd
I have a spare hard drive though it's a Seagate Barracuda 300gb (7200rpm), I will probably upgrade this later on as it's quite old however I am wondering whether it's fine for now. I have DVD drive, and I haven't included Windows 7 in my budget or build.
Having read a lot of things on the internet, I think this should be OK, however I'm unsure whether it's worth spending a bit more on the motherboard and whether spending a bit more on an 80 Plus PSU is actually worth it. I'm also undecided on which graphics card to use, between the GTX 760 (EVGA Superclocked) or the HD 7950, or maybe another card?
Any thoughts?
Thanks
