Gaming PC Build
Hello there, people of the internet. I'm trying to build the best gaming computer I can under about $800 and one that could be used for the next two years without serious upgrades. So far this is what it's looking like. All feedback is welcome.
    Thanks
CPU:  AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket
        http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
Graphics Card:MSI GeForce GTX 660 Ti 2GB 192-bit
       http://www.newegg.com/Product/Product.aspx?Item=N82E16814127696
RAM: Mushkin Enhanced Silverline 8GB (2 x 4GB)
       http://www.newegg.com/Product/Product.aspx?Item=N82E16820226095
Case (not spending much on for now):Rosewill R519-BK Black ATX Mid Tower Computer Case w/ 500W Power Supply
       http://www.newegg.com/Product/Product.aspx?Item=N82E16811147081
Motherboard: GIGABYTE GA-78LMT-USB3 AM3+
        http://www.newegg.com/Product/Product.aspx?Item=N82E16813128565
Disk Drive: LG 24X DVD Burner - Bare Drive
        http://www.newegg.com/Product/Product.aspx?Item=N82E16827136259
Hard Drive:Seagate Barracuda ST1000DM003 1TB
        http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840
If you don't really need the drive, this is very close to your budget
If you do the need the drive, and can spend $20 more, this.
