So, i want to build a PC for gaming but i don't know what PSU i should buy...Here is my config :
AMD FX-8350
Asus SABERTOOTH 990FX R2.0 ;
Sapphire Radeon HD7870 XT with boost ;
Corsair Vengenance 8GB 1600MHz CL8 Dual Channel ;
Seagate 1TB 7200RPM 64MB Barracuda ;
Cooler Master HAF 912 PRO (case) ;
Arctic Cooling Freezer 7 Pro rev.2 ;
SSD Kingston 60GB SATA 3 2.5 inch V300 .
nice solid build man.
I like this evga power supply though. To me it hits the sweet spot for features and power.
http://pcpartpicker.com/p/17G9O
I also like this case better.. and it has front USB 3.0.
Here is another case that is a good deal and has good build quality
http://pcpartpicker.com/p/17Gqh
If you can wait a little, GTX 770 4gb should be out soon.. and there are a couple models floating around.. they are worth checking out. They should retail around $450.
