Hey guys I am going to build a PC for gaming and was wondering if these parts were good and all the best for the money. Also I am mostly going to be gaming, but I will also be doing work for school (no real intensive software though)
Build: http://pcpartpicker.com/p/KqTT
Also will I be able to run Crsis 3 at 1080p at 30+ fps, can I run bf3 1080p 40+fps, and dayZ 1080p 30+ fps.
i edited youre build. cause you want to play BF 3 atr 1080p then you realy need a quadcore cpu.
http://pcpartpicker.com/p/Kr4y
i choosed for a AMD FX6300 6 core cause it does realy good gaming performance.
And if you can afford it, then a 7870 2GB or a 7950 gpu card, is a better choise for those games. but the 7850 is also a good card. but if you wanne run those games maxed out, at 1080p then maybe a 7870 ghz edition or a 7950
