Gaming PC Build - £1000
Okay, so I have a £1000 budget for a PC, keyboard, monitor and desk. The desk I have found costs £80 and the keyboard £120. So that leaves me with £800 on a gaming rig and monitor, suggestions would be appreciated.
Intel Preferred and Nvidea GPU preffered
Many thanks in advance :)
[EDIT]
I should add that i want to livestream games on twitch at max settings at 60fps if possible
===================================Ogre=====================================
I think it might help other members if you list what games you had in mind. and why are you Nvidia and Intel pref? Are there certain programs you run that are optimised for those brands? because its narrowing down your range a little. Also, will this build have to include a mic/web cam?
Thanks
http://uk.pcpartpicker.com/p/4Mqt99
