Read through a lot of threads. Searched a lot on net. And so I am not going to ask a question in which you chose between options. Here is the config I came up with:
GPU - AMD R9 280x 3Gb (http://mdcomputers.in/SAPPHIRE-GRAPHICS-CARD-DUAL-X-R9-...)
CPU - AMD FX-6300 (http://mdcomputers.in/2092-amd-processor-fX-6300-black-...)
RAM - Corsair Vengeance 8 Gb (4Gb x 2) (http://mdcomputers.in/260-corsair-ram-vengeance-4gb-ddr...)
Motherboard - Gigabyte GA-970A (http://mdcomputers.in/2081-gigabyte-motherboard-970a-ds...)
Now, I am a total newbie when it comes to building PC from scratch. Are the above components compatible with each other?
Also, please reply with what else do I need and the brands/model number I should be looking for? (Optical Drive, PSU, HDD, Cooler etc.)
Would be helpful if the suggested items are available and in stock on these sites as I am from India:
http://www.flipkart.com/
Also, in case there are any other better (but not expensive) alternatives to above mentioned configs please feel free to reply. I am not an AMD or an Intel fan. It's just AMD is much cheaper at least here in India.
Most important factor for me here is:-
Be able to play Assassins Creed: Black Flag (AC4) at highest settings on a HDTV (1920x1080) without any lags.
Thanks,
Edd
Extras/Not Important Stuff:
I had also shortlisted following config options but picked (and mentioned) the ones with VFM-
GPU - Nvidia GTX 760
CPU - Intel i5 4670k
Motherboard - MSI 970A-G46
