So you did swap to a board that has above 4GB decoding… and still that? That sucks. Also, don’t reply to this asking if I know a fix; if I had a suggestion, I’d say it.
The average board will run both at x8 like that.
As time goes by, I’m sure you’ll think of that less as an upgrade, and more as a mistake, until getting a more typical GPU or finding some magic fix. If remote play is good for you, you can set it up to run headless (without any video outputs) and get good compatibillity. Have your output GPU not support vulkan/DX12 and you’ll likely have better luck with games that use those APIs.
The fucking what with battle eye?
Whatever they’re anti cheat is called LMAO
I wasn’t aware that was a problem with a Tesla.
Maybe they fixed it or only a thing with Radeon cards but it was last year
you can try to use windows 11,it can manual selection graphics card to play game
Mainly FFVII Remake, but finally got that to work super late last night. Don’t recall how though. I thing using drivers in manual install
it was out of curiosity. Ended up with it after doing several jobs for a client that got it for resell.
using Windows 11 and windows 10 and testing in both. Win 11 plays more nicely.
Hey dude So for youre setup this should sopve yourse issues with the enable mshybrid have the tesla set to 1 and for youre nvidia card add enable mshybrid to 2 reboot and in the windows gpu selection should show the tels as the high piwer card
@GigaBusterEXE
hi,guys
i have a idea,can use gt1030 ?
is it must be Maxwell2.0 or other ,if opengl can use success ?
You have to use the newest driver, supported by the oldest card
You can use any Kepler, Maxwell or Pascal card, you just have to keep the top statement in mind
Solid general advice.
have you tried what i suggested
as long as the driver is shared between the two nvidia cards there shouldnt be any issues just disable auto windows upadte as thats always trying to install the newest driver and nvidia doesnt allow two drivers running at the same time can be done in linux but not in windows
Big thanks for the advise, that actually worked in both W11 and w10. the note about drives having to be on the same version was one of the first issues that I came across when tinkering with the m40 months ago. Again, thanks for that small detail.
No worries there are a couple games it doesnt work on but 99 percent just work
yeah i swapped my mb, still dont work - i might switch to another mb for the final time but if it doesnt work then ill give up.
