Hi, first what OS are you using? Also when using DDU in safe mode did you go to options to make sure there is a check mark by "prevent downloads of drivers from “windows update”?
windows 11 and yes about ddu i did notice in the registry there is a new entry that wasnt there with previous drivers R535_4181821 and if i delete it. then its back to freezing etc…
This is what my Registy looks like , I’m using driver 537.13. That looks to belong there as is. edit: I’m also on W11.
hmm well I am going to try this card in a different pc bc thats pretty much the only thing left to try.
BTW on the modding bios front I found some interesting commands related to clocks and falcon buried in an engineering release that I think might help.
That sounds interesting about the engineering release.
There could be one other thing to check in NCP, make sure ECC is disabled.
Edit3: Everything else looks like below? BTW I should have said I’m on W11 Pro .
I’m using the Quadro driver: 537.13-quadro-rtx-desktop-notebook-win10-win11-64bit-international-dch-whql
I’ve had ECC enabled pretty much the whole time I’ve had the P40. When I updated to 537.13 I also disabled ECC. Benchmarks ran fine and got a slightly higher score as expected, but Starfield or BG3 did not launch. So I now have ECC enabled again and the games run fine. Have you tried with ECC enabled?
Hi, I do not have either of those games so I can’t say one way or the other if they would work for me. I looked at downloading both but not willing to buy just for a test. lol
Very new here… been lurking.
For the GAL.
For mixed usage, including plex transcoding and vGPU gaming via moonlight, would you guys recommend an M40 or P40?
Encoding info
GM200=m40
GP102=p40
A titan Xp clocked at 1950mhz performs about as well as a 3060, that said, a p40 which is the same chip, probably will not go much farther than 1500mhz unless you can get it to overclock
