Hello lvl1tech Family.
I need some help, i am in the market for a gaming monitor and im looking to spend between $300-400.
Was thinking of the HP Omen.
Any suggestions would be great!
Thanks.
Thanks.
Hi can you add a little more detail? What graphics card are you using? What sorts of gamess do you play? Is it only for gaming?
Good thing you asked,
Running a gtx 980. Play a variety of games from dayz to league to gta5.
Gaming mostly.
Thanks again.
I guess you're looking for something like 27 inch 1440p with high refresh rate (where you can get it).
http://pcpartpicker.com/products/monitor/#W=2700,3200&r=256001440&H=60,240&X=74,30722&sort=a8&page=1
doesn't look like there is a massive choice of . I'd go for the Asus because 75hz. There may be some cheap Korean monitors like suggested here
It really depends if you want more pixels like 1440p or if you are fine with 1080p gaming.
I got myself a nice 120 Hz Benq 1080p monitor and I love it. Got it for 150 Euros used and its so nice to have smooth gameplay. I would definitely recommend that route, but I am also more of a FPS guy.
QNIX 27 inch 1440p monitor is great. All you need is a plugadapter from Korean to US. It can also be overclocked to 100hz with no stability issues.
Also one of the most stable panels for gaming I've ever used. Practically 0 screen tearing or skipping compared to every other monitor I've used for gaming. And has VESA mounts on the back.
Only 1 downside is there is only 1 dual link dvi port for it.
Thank you all for your help!!
Looks like i have a decision to make.
The QNIX is pretty nice.
I would recommend getting a VESA mount with it, for height adjustment.
