Gaming Monitor-1920x1080 or 1600x900?
I am making a build on pcpartpicker and im at the monitors, i can either upgrade to a 1920x1080 or stick with my 1600x900 monitor.How different would it be if i upgraded?should i save the money and keep my current monitor? i will be using a Radeon 7970 with a FX 8350 if that makes a difference or not.
heres an option since you have a 7970(lucky) you can use the 1920x1080 monitor as a primary monitor and the other as a secondary monitor so you can take advantage of your gpu. but its just an option if you need the money then stick with the monitor and if not go with my option
Im going to stick with my current moniter and ill upgrade later,Thank you.
you're welcome
