The first thing that you need to understand is High DPI does not mean higher accuracy. It is a marketing gimmick. Pro fps players typically never use above 900dpi.
brands make high dpi mice because the masses assume it means higher accuracy, but it doesn't, and it ends up hurting the mouse's performance at all dpi because to make it playable at high dpi they need to eliminate jitter by processing data heavily which creates lag.
If you're set on those 3 mice. I would probably recommend the Sensei. I think it has a fairly reputable build quality, while i can't say the same for the other two. It is a laser sensor and does have a little bit of acceleration which is generally considered a negative trait, but it isn't a horrible mouse sensor wise. Do not get the MLG edition of the Sensei, though, it is widely considered defective.
If you're open to suggestions for cheap, the logitech g100s and cm storm xornet are very decent cheap gaming mice. You probably want to run them at the lowest dpi step they have, which is probably 400-800, but many professional gamers still use 400 dpi. High dpi does not mean high accuracy, so it is a non issue. The other downside would likely be a relatively low perfect control speed. Which means that if you whip your mouse across your mouspad, its not going to track consistently. But the average gamer uses a relatively high sensitivity and it becomes a non issue. One issue you might have because of your old mouse is that these mice are fairly light and you're probably used to something very heavy, if you think a mouse being light would bother you, you should probably invest in full priced gaming mouse.
If you use a medium to low sensitivity, maybe 18cm to do a 360 degree turn in a shooter, or farther to do a 360, then you probably should invest in a full priced gaming mouse because you probably can move the low priced mice fast enough to track inconsistently.
So mice with high dpi create lag, but most full priced mice have high dpi. You can buy a full priced optical fps centered mouse, that will have a little lag, but good in every other regard, i would recommend the logitech g400s, Steelseries Rival, and Razer Deathadder in that order. Or you could get a zowie mouse which has a low dpi and high perfect control speed, so low lag, high end, great tracking mouse. Their downside is lack of customization. They have 1 native dpi step at 2300, and 2 interpolated at 450 and 1150 i think. You want native, so you would want 2300. For Zowie you probably want a ec2 evo cl for right hand mid size ergonomic mouse. If you have a big hand, get the ec1 evo cl. If you want ambidextrous, the zowie fk. The FK is very light though. possibly lighter than the g100s and xornet.
