Hey all,
Planning a build mainly for gaming but would like to use it for architectural design as well so I don't have to pack my bulky work PC home.
The main game that I play is EVE Online.
Cad systems would include Autodesk Revit & Autocad. I will be rendering in Revit at times.
I'm planing on upgrading the build in the future, SLI GPUs is a high possibility if that's feasible.
I don't know much about overclocking CPUs but that's another future possibility.
Hoping to start off with something around $1,300 or cheaper for the build.
Would this be a good start?
http://pcpartpicker.com/user/NuvisReeval/saved/28848d
(Currently not showing GPU price which was $230 earlier, with a total of $1,317.00)
I'm open to all input and appreciate your time to help out.
Thanks,
-Nuvis
