Gaming computer help
Where would be a good place to buy a good gaming computer other than alien ware?
Build one. Many people here would inform you and help you on how to do so.
Much better than buying a pre-built system. You will know what's inside your system and can adjust it to your liking,requirements, and budget.
Also pre-built gaming computers often cost more then what they should.
there isn't a good place custom is the ONLY way to go, give me your budget and the country you live in
Not to mention how much you will learn by building your own.  Trust me, just finished my first a few weeks ago.  BEST damn computer I've ever owned too...
thanks guys i thank that you all just helpme . i thank i well just build one
