Hey, I'm eventually preparing to upgrade from my current 775 setup... (so, below is a run through of the guidelines)
Budget - haven't really got one. It'll just take longer to compile the parts. If A costs more than B, but the price is justifiable, then I'm happy to spend a bit more.
Location - UK, so currency is GBP (£)
Peripherals - Yup, I am going to need those at some point, but I'll be doing those separately (depending if I end up needing a rendering rig). I am intending to have a surround setup; so 3 monitors in 1440p (+ an accessory display).
Usage - This is going to be a gaming rig, but it will be used for SolidWorks 2014 (designing and rendering) as well. I do know that this may not be completely suitable as a rendering rig for SolidWorks - so it may end up as just gaming...
Overclocking - Yes. CPU definitely, possibly GPUs as well...
Cooling - Parts are to be air cooled in the first instance, but this will end up being my first water cooled build in the future.
OS - Windows 7 x64 (already bought a while back)
Gaming
I like eye candy, so aiming to run with all the setting maxed with as high FPS as possible
The resolution will be 1440p on a single screen to start with, but aiming for surround (3 screens)
The type of games are normally FPS, but there is a bit of anything really. - Skyrim, GTA (3, VC, SA, 4, 5?), BF4, Sleeping Dogs, Half Life (1 & 2), F.E.A.R (1, 2 & 3), X-COM, etc...
Rendering - SolidWorks 2014 is currently the only software... but this may have to be pulled to a separate rig due to hardware constraints (Quadro / FirePro / FireGL)
Parts list, as it stands... Yes, I do have some dumb / strange ideas & queries below
Motherboard - ASUS P9X79WS-E
CPU - ? (IVY-E)
RAM - ? (16GB / 32GB Corsair Dominator)
GPUs - ? (770 / 780 / 780Ti) - 1 to start with, increase to 2 or 3 when I get new displays.
GPU - ? (Quadro) - Quadro + Geforce can work, but not sure if it will in the way I want... so it may end up in a small CAD rig.
TV card - not a clue on this... effectively I want an S-Video input
Case - N/A - custom, designed around the parts... space shouldn't be an issue.
So, queries...
Storage, is this a dumb idea? - 3 SSDs in RAID 5 with some of the RAM as a cache... Plus 8 HDDs in Raid 5 / 6 with an SSD for cache.
http://uk.pcpartpicker.com/user/deejeta/saved/3e1H something to work with i suppose - 2 1tb ssds could be in raid 1, wd blacks in another raid. No real need to have more ssd's as cache. You can easily allocate some ramdisks out of the 32gbs to create some scratch disks. In terms of the board - im always dubious to suggest running such a large array of a motherboard, but from what Ive read on this board the onboard controller seems to do a reasonable job at handling things.
does solidworks support opengl? If so then maybe something like the new r290x's would be worth a look
I'm not sure why you would want to put your SSDs in RAID 1 or 5. If it were my machine, I would just run two SSDs in RAID 0. Keep anything important (photos, movies, projects, work/school material) on your mechanical drives which would presumably be in a redundant RAID array. I would actually consider putting all your mechanical drives in some kind of NAS to be honest.
If you're not completely sure if you'll even do a lot of CAD work on this machine, I would stick with a gaming card. The gaming cards should be enough if you really need to draft something in a pinch.
For your TV card, why do you need an s-video input? I'm not quite sure if this works in the UK, but if you are just trying to watch TV on your pc, you may be better off with something like the HDHomerun Prime. You would then be able to watch/record your cable television on you hard drives, get a good guide, and you can stream your cable tv to any extenders you may have on your network as well (e.g. an xbox 360 in your living room). Again, I'm not sure if you can use this device in Europe.
Hi deejeta, my plans originate back from socket 1366 releasing (and adjusted as and when new things released) - so, I've got a couple of queries...
You'd go as big as 1TB for the SSDs - the price / performance is worth it compared to smaller SSDs and fast mechanicals? I'm coming from only mechanicals, so I have to ask ;)
WD Blacks over WD Reds? - I know Reds are normally NAS drives, but 4 crammed together can be considered NAS like conditions(?)
8x 4GB sticks vs. 4x 8GB sticks...? - does the memory controller still have a harder life when using all slots?
SolidWorks does have support for OpenGL, it looks like you have to mess with the drivers to make it think that it is a ProFire card...
Hi crazymobster, the storage ideas come from one or two of Tek Syndicate's videos and one of JJ's (ASUS) videos... hence asking if the ideas would work together.
Logan had said something along the lines of a single SSD, but you could upgrade that to 3 SSDs in RAID 5. JJ had said about helping RAID performance on mechanicals by using an SSD for cache (a friend has been doing this / similar to this for a few years now). One of them had mentioned RAM Disks / RAM cache for SSDs as well... So, it's a mix of ideas, but don't know if they'll combine into something brilliant, or something that won't work. I do have a NAS for backups and such, but I wouldn't want to be working off it constantly - hence wanting a decent amount of storage on this PC.
The CAD aspect, is more for eye candy TBH, they state ProFire / Quadro cards are needed as they work differently to the gaming cards, but that just restricts some of the more complex surface textures. I can and do design / assemble / render on a Geforce with no issues. So, yeah - might just keep this as gaming and build a CAD rig in the future.
The situation with the TV card is that I have 2 AV amps - one in my office and one in my bedroom. The amps are linked and can send Audio / Video from the devices in one room to the other, and vice versa. To complete the setup, I'd like to have the PC take the video (S-Video) as well as the audio - so I can watch and listen what is on the other devices. The setup worked on XP, with my old TV card, but that thing doesn't work on Vista, nevemind Windows 7.
