Hey guys currently I have a FX8320 and a GTX660ti, works great as a gaming pc. However, I'm a physics and engineering student and need a little bit more power (and pleasure). I'm looking to do multimonitor (2x 1920x1080) and I was wondering whether a GTX660ti is good enough. This setup would be primarily for gaming and a little CAD and computation for classses(why I have the 8320).
If someone could advise me on whether this is viable or whether to upgrade my hardware.
Thanks.
P.S.
First post so be gentle and give me some advise on how to make my posts better.
1500-1700 is a pretty damn good budget for a full rebuild. A lot of your computer is still pretty good for your uses, though.
http://pcpartpicker.com/p/2RKO9
Here is all you'll really need to upgrade.
I switched the motherboard as this one has a stronger VRM system, which will allow you to overclock that 8320. You may want to look for a new CPU cooler if the one you have now doesn't perform as good as you want it to. I'd recommend the Noctua NH-D14
For the GPU, I picked the R9 290X. With 4GB of VRAM, it's great at high resolutions or setups with a lot of pixel count. The 512 memory bus will also help as well.
CX500 power supplies are good, but a power hungry GPU along with an overclocked CPU may be drawing too much for the power supply to handle. I bumped it up all the way to 850w. This allows you to add another R9 290X comfortably. While you have your single R9 290X, the power supply will run incredibly quietly and cool since it's not being stressed out. The power supply uses all japanese caps, is fully modular, and 80+ Gold certified.
And then I got an identical monitor to match the one you have now.
Thanks, I actually forgot to change the PSU (I actually have a 1000w). As for the budget, I do webdesign in my spare time and work for my professor and I would sell my old pc.
I am curious though, if I were to do a rebuild as a mini ITX system would you recommend the 290x or a 780. The 290x has some heat and noise issues.
