Gaming Build
Hi guys, just going to follow the template here, thanks in advance for the help!
No more than $700
I use US Dollars
Peripherals would not be included in this build, I will take care of this on my own. Same with monitor and OS
I will be using this for mainly gaming, possibly digital painting, and school work.
I am not experienced in Overclocking, but i might try.
I am not interested in water cooling.
I am also not interested in BTC mining.
I would like to play in pretty high settings (Upgrading from a laptop w/ Intel HD 300 xD)
I would like to play games like Planetside 2, Skyrim, Dishonored, Starcraft 2, DayZ, Destiny (WHen it comes out), I am also very much into Indie Games such as Starmade, FTL, and Antichamber.
I will probably use photoshop for digital paining.
Other details, I prefer AMD, just because of the bang-for-the-buck. Also, try to squeeze out every dollar you can for this build!
Thanks!!!!!
http://pcpartpicker.com/p/1LJi9
it has a very nice case and good components a good case makes building so much easier and its the part of your computer you actually see
How much would faster RAM impact the build?
This but I would hold off for AMD's Hawaii GPUs. They are coming out this month. Just get the one around the same price point.
not much since you are not using an apu because those are for low end computers.  like the comment below you could also get an r9 270x at the end of the month or a 7950 price drop
Do we have a an exact date when they will be released?
I would also consider an Intel cpu and Amd gpu combo. Simply because I see a lot of games which are a barely multithreaded and or cpu bound. StarCraft, Skyrim, Planetside, Day z in particular.
not that I know of you cant really go wrong with the 7950 the new gpu's are going to be based off the 7000 series besides the R9 290x but that one is going to be like $700.  I would still say that a 7950 is probably about equal to the R9 270x dont know the performance just a guess based on price and specs.
The nondisclosure agreement ends October 15 so that is mostly the GUESS of a couple of big tech sites but no, the true release date hasn't been announced by Amd.
What cpu would you suggest then? Its just that they are really expensive, compared to AMD for performance.
unless you are going to up your budget and get a i5 4670k the fx 6300 and fx 8320 are the best bang for the buck
http://pcpartpicker.com/p/1LMCK
no overclocking. Slightly weaker graphics card. Link to difference in single threaded.
http://cpuboss.com/cpus/Intel-Core-i5-4570-vs-AMD-FX-6300#performance
Also sources for why I made the suggestion. Just to note, an 8350 is more powerful than a 6300, the i5 4570 is slightly less than the i5 4670. The i5 4xxx series is more powerful than the i5 2xxx or i5 3xxx. and the amd x3xx is stronger than the x1xx series. I say this because benchmarks are usually done for the top tier. You just have scaling it down.
http://www.tomshardware.com/reviews/gaming-processor-frame-rate-performance,3427-6.html
http://www.tomshardware.com/reviews/gaming-processor-frame-rate-performance,3427-8.html
http://forums.videocardz.com/topic/188-planetside-2-performance-test/ (this one is farther down the charts).
