Gaming Build
Hi guys i need some help building a gaming pc that's goin to last even if i have to do upgrades later on. My budget is not really set in stone cause i want some good components but let's say 1600$ without keyboard, mouse and monitor. Feel free to go over the budget, im willing to go as far as 2000$, i want some good advice as i have always seen from u guys.
Here is what i got so far: http://pcpartpicker.com/p/1IqX9
That 7970 is too expensive, you can almost get 2 7950s for that price. For pure gaming performance intel is still ahead, though there might be some change in the future with the consoles being from amd.
http://pcpartpicker.com/p/1KnPN
With your budged i would wait for the high end r9 models, depending on your storage need you could also ditch the hdd, get a 500gb ssd and put in another one later if you need more storage.
Avoid the MSI twin frozr cards for the 7900 series, I have heard a lot of cooling performance issues from that set up. You can also wait for the r9 280x to release it is the GCN 2.0 version of the 7970 and I think it is supposed to release at $299.
