What do you guys think?
http://pcpartpicker.com/p/KHp7
I was giong to use my tv instead of a monitor to save money. Feedback/recommendations would be appreciated. I'd also like to know if anyone could recommend a wifi adapter?
This is literally the exact same build im doing atm, So i have to agree Its a strong build for the choice, just wish i had more money for a 7950 but its k, just overclock that HIS like it was made to be.
Could you post a [u]permalink[/u]?
The reason for that is because it IS your build, not the OPs. The OP didn't post a permalink, so the link will take you back to your build.
I did.
good build but windows 8 is not that good so i would reccomend windows 7
oh and also if u choose a sapphire or an xfx 7950 u get crysis 3 and bioshock infinite free
and lastly i would also go for the hyperx 3k instead but thats just me
