Gaming Build, need help
So i've tweaked it a little bit to get around 500 bucks lesser. My questions are is it good, will it max all games (maybe some future ones too, bf4, witcher 3, etc.) and is it bang for your buck. I'm open to suggestions. thanks. http://pcpartpicker.com/user/GGNORE/saved/2m4p
Do you plan on getting a second 7970?
If it comes to that, then yeah I might.
Well, if not, then you don't need a 650W PSU; a 400 or 450 will do just fine, and save you money through efficiency.
okay, could you pull up a 500w for me? I'm not sure which is the best. I've had corsair before, but i know there are other competitors who are just as refined. whatever you recommend.
Corsair is just a company that pays others to slap together PSUs for them; they use a lot of OEMs, on their lower end, usually CWT, but on the higher end, some Seasonics, which are decent.
I would personally get a Rosewill Capstone 450, which is really efficient, well built, and plenty cheap for the ripple it puts out.
http://pcpartpicker.com/user/GGNORE/saved/2m4N k, went with 550w. also for modular, cables really do mess with me. I plan to oc the cpu, will that work with the psu.
also im looking for speakers too (already have headphones) Can anyone recommend a good set of speakers?
I would reccomend this mouse over the death adder http://www.amazon.com/Zowie-FK-Buttons-1xWheel-Competitive/dp/B00CVPRE1U/ref=sr_1_1?s=pc&ie=UTF8&qid=1378767083&sr=1-1&keywords=zowie
Or this http://www.amazon.com/ZOWIE-Optical-Gaming-EC1-eVo-Black/dp/B0080HLJGO/ref=sr_1_6?ie=UTF8&qid=1378767555&sr=8-6&keywords=zowie
