i need some recommendations on a good Gaming mouse and Gaming keyboard and which of these moniters should i get? Once i get a new computer i think i need to upgrade the moniter, right now i am using a working moniter but its 1600x900 and i want a 1920x1080
Gaming mouse/keyboard, hue hue hue hue. Just don't buy Razer's overpriced crap build quality light up kiddy peripherals.
So before this gets flooded with bad advice, I'll tell you that you won't do better in games because of a mouse or keyboard, if you suck, you suck. Why not spend the money on a much nicer monitor say 23" and a 1080p IPS panel? Just a thought, but if you're sure your KD will go up from a nice mouse I'd suggest the Logitech g400. It has a perfect laser sensor with no angle snapping or prediction like Razer mice so it has the most accurate movement. As for a keyboard it depends if you want mechanical or not.
Logitech, Zowie, and Steelseries make the best mice imo. I have a Zowie AM atm and my god it's awesome. I think a nice mouse WILL improve your playing. Especially ones with 2 buttons on the side for crouch/jump or whatever.
If you don't want mechanical, you can probably find this somewhere cheap http://steelseries.com/us/products/keyboards/steelseries-apex-raw-gaming-keyboard , I'm just assuming it costs more from their site. But I LOOOVE this thing, would pick one up myself if I didn't just get one and wasn't stuck on mechanicals. Once you go mechanical you'll never go back.
I think this, or a Ducky is the best mechanical keyboard http://www.daskeyboard.com/model-s-ultimate-silent. Now most mechanical boards DO sit high, so a wrist wrest could be nice. I'm not really buying into the Razer hype.
