Gaming build for $600!
Hey there guys!
I need a PC build, mainly for gaming on modest games such as Battlefield 3, Skyrim, Far Cry 3, and the likes of that.
It has to include a monitor, and any old keyboard and mouse.
As long as it can play with around 30+ FPS on medium or higher, it will do!
Don't mind APU's, and I'd like a nice bit of airflow.
http://pcpartpicker.com/p/BQzE
you can pull money from the cooler, and drop to 2133 ram if you want a better monitor. I figured any old 20" would do the trick.
You should say if you already have any one particular part so the lists that people post are more..effective xD
http://www.cpu-world.com/CPUs/Bulldozer/AMD-A10-Series%20A10-5800K.html
If you look at that, it says the maximum supported memory speed is 1866. No point in going higher.
Strange, because i've seen benchmarks with the A10 using memory stock clocked over 1866MHz.
there is always a point in going higher you can OC the memory controller to perform at the faster speeds its trial and error but it has been done
What dex said. That the reason for the nicer than average cooler, and the nicer than average mobo.
Here is a build for you
http://pcpartpicker.com/p/BOZl
