http://pcpartpicker.com/user/PCpowerRule/saved/3BRj
Also Need advice on a Monitor for $250 or less, and maybe a 27" monitor.
Any suggestions on keyboards for $150 or less would be great as well
All criticism accepted on my build, got most of my info from Logan's Video on a $1200 build. http://www.youtube.com/watch?v=ZIS6zyBkoKY
I did find you a nice monitor that is going for about $210 and a good keyboard for $120. Here is the link. I hope that this helps. I am still new but I think this might be good for what you are looking for, based off the reviews.
Looks alright. If you want to lower the price a bit, here's what I managed to whip up:
http://pcpartpicker.com/p/2O743
If you want to do any decent amount of video editing/rendering, then look into higher clocked RAM. Otherwise, 1600mhz will work just fine. I also got a better power supply, which is also semi modular (w/ a 750w, modularity is a godsend due to amount of connectors). The noctua cooler matches somewhat with the board, and will also run really quiet. I switched out the Kingston HyperX kit to a Samsung 840 Evo. If there any reason you want the kit, then you can always change it again.
@the new guy, Thanks for the link to the monitor I will do some research into that 27" looks pretty nice and I really like Asus.. and Thats the exact keyboard (except I went with the green one) I decided on this morning I seen it on amazon. lol thanks for the reply
Thanks for the advice on the power supply, I am definitely going to research some more on power supply and semi-modulars (not much exp. with them). I went with the 2133 ram because I am getting into game development, starting ECPI at the end of February 2014.
Thanks for the price cuts though, great Ideas.
My pleasure! Good to hear that we had the same thing in mind, haha! Enjoy your PC and take care!
