Ok guys,I need ton know if this system is too much over kill. I'll be useing it for pretty much everything. I already have the ram and a fractal R4 mid tower case http://pcpartpicker.com/user/Rayn34/saved/1YNN
id say swap those r9s for a gtx 780 or 780 ti and get 2 or 3 3tb hdds over that 1tb ssd
If you have the cash, why not... Should be a beast. You'll need some extra case fans though to remove the all that heat.
Am I right in guessing the 120gb drive is just for the OS? If thats the case then why not just partition off a little space from the 1tb ssd and save yourself $100 - you could get a bigger monitor with that saved cash.
Ok, thanks. I'm actually looking at tax season for buying the stuff.
