Game Help
heres my current build
EVGA gtx 970 ACX 4gb 2.0
intel I5 4690k
Crucial MX100 128GB 2.5" Solid State Drive
hyperx fury 16GB DDR3-1600 Memory
WD Caviar blue 1TB harddrive
Asus Z97-A ATX LGA1150 Motherboard
Noctua NH-U14S 55.0 CFM CPU Cooler
Corsair CS series 750w power supply
fractal design r5 mid tower case
for some reason i tried playing saints row 3 just to see how good i could go it wasnt even doing 30 fps on low detail, any ideas what software i might be missing or something?
Check out www.pcgamingwiki.com and look up Saints Row 3. Could just be a game issue. That is the place to go with game issues, and if you have any fixes post them for other in the future.
What resolution and settings are you playing with? Do you have the nVidia drivers installed?
just figured out i dont have the nvidia drivers all installed so going through and doing that
