So got a G7 today, unlocked it and now am trying to get TWRP on it. Running into some trouble.
anyone have a clue for me? I didn’t see anything online
Depending on the distro, you may have to add your user to the correct USB group in order to write to the connected device.
Alternatively, try running those commands using sudo (or by switching to root.)
I tried root, same error. It should be good on the USB front as I was able to unlock it and put it into fast bootmode via USB.
I did notice that in fast boot it says “AP Fastboot Flash Mode (Secure)”. Could that be the issue?
