I'm considering getting a new monitor and I've been wondering, are there any 1080p monitors that support G-sync and 3D and have great response time and great picture and no ghosting (or as low as possible as I'm not sure you can ever completely get rid of it)? Also, if they would look nice with a thin bezel that would be great too.
While Googling this stuff I keep finding people asking about either just good monitors with low ghosting or just the best 3D monitors, but could I have all that at the same time? Note - it should be 1080p (not 1440p) and as for the size... let's say 24-27 inches. Are there any out there that are the "obvious choice" in this case?
Too bad :( I mean the resolution. I'd like to watch 3D BluRay movies on it and I prefer native resolution, not having the movie upscaled to 1440p so that's unfortunately a no-go.
Well I hope there will be others out there in the future.
BTW, just a note (in case it's unclear), I'm referring to monitors that just HAVE both G-Sync and 3D, not necessarily ones that use both. I mean, if I would watch a 3D movie, I obviously don't need G-sync and I wouldn't mind if it wouldn't have G-sync while 3D-gaming, but if I play a regular non-3D game, then it should utilize G-sync. I don't expect it to game in 3D with G-sync on (though that could be a bonus).
I know , I can't filter out those options on the site , so I put all G-Sync monitors , you will have to choose the 3D ones on your own .
But if you want my opinion , 3D isn't worth it , I have a 3D monitor ( but I AM daltonian ) and 3D gives me headaches and I can't see stuff well in game .
But 144/120 HZ is 100% worth it , just I wouldn't pay extra for the glasses .
Got it :) I'm considering 3D mostly for movies and yes, it's a bit of a gimmick, but... I don't change monitors a lot, I went through 2 PC updates already while still keeping my current screen so I think, if I'm going to pay for a new one, then even if I overpay a bit, I'd rather have this as an option.
Otherwise, if I would want 3D in the future for some reason, that would mean getting a new screen again. Anyway, I'll see what I can find :)
