FX8350 temps
Hey there guys,
I have OC'd my FX8350 to 4.8Ghz.
My OC specs are:
Multiplyer: x24
Bus speed: 200
HT Link: 2207
Core voltage: 1.476 (which under prime95 small FFT goes to 1.50)
I ran small FFT for approx 45mins (for each stress test prior to overclocking more I test for 30mins)
I would have run the test for longer but i was scared of the temps which were:
CPU temp: 67C
Package temp: 50C
I was using HWMonitor to monitor the temps.
Would you guys say this was a stable OC or i should go a little lower due to temps?
Thanks,
Ben.
I also attempted using muliplier at 20 and bus at 240 and same temps
The temps are ok but you should not go any higher than this. 4.6-4.8 ghz is the sweetspot for this cpu and anthing below 70 c is a safe temperature.
I have heard some people say 62C is the limit? And ok man, thanks for the help!
