Fx-9370 worth it?
I was just wanting some thoughts on the fx 9370 it is $237.99 on amazon. At $38 more than the fx 8350 That is less than the difference between the fx 8320 and fx 8350. You could probably get at least a 4.8ghz over clock something that is not possible on all fx 8350s. Just wanted some thoughts.
if you have a good mother board and you arnt overclocking then its ok.
Personally, I think the 8350 is plenty. The other way to look at this; you could buy an 8320 and overclock it to speeds similar to the 8350, saving better part of $100 (versus the FX 9370).
If you really want to spend that kind of money for a productivity chip, grab an i7 or go 2011.
if you're buying it for extream overclocking, then it's very reasonably priced if you want a better binned chip
that said you bet your ass i saved $30 and got an 8320
Yes, that's a good deal if it is the one that comes with the water cooler.
Thanks for the replies. For now i will stick with my 8350. Maybe If the 9590 gets cheap enough I will get it and see if I can get past 5ghz on water.
