FX-83x0 VS. i5 4670k (for me)?
Hello all,
I am generally a LinusTechTips forum regular but I thought I would get this communities opinion on this subject.
Being a teenager I don't have a job and thus no steady income. Meaning that I am on a budget for this PC. Others (such as on r/buildapc, and overclock.net) have told me that I should put forth the extra money for the i5 4670k rather than the FX 8350/8320. I would be willing to do this if it is worth it but since it is a more expensive CPU it would most likely mean that I would not be able to get as nice of a motherboard. Is the 8350 suitable for my gaming needs or should I put forth the extra money for the i5 CPU(I typically play games like Fallout, The Elder Scrolls, Bioshock, Far Cry, The Witcher and I also occasionally play games like Battlefield and Counter Strike). Any opinions are appreciated.
I have an 8320, and it runs all of the games you listed just fine. I used to have an Athlon II X4 which couldn't even run Planetside 2, but this processor has handled everything I've thrown at it very ably. The higher-end Intel CPUs are generally overkill for the average gamer, and in my opinion the price/power ratio is not quite as good.
I would go with the 8320 personally if you are on a budget pair it with an asus 990fx motherboard and get like a hyper 212 cooler and overclock a little and it will be plenty powerful.  My freind has a fx6300 @4ghz and it handles bf4 dayz arma what ever just fine compared to my i7 so I would go fx8320 with a 2x4gb set of ram at 1600mhz or better http://pcpartpicker.com/p/13dbB
Both CPUs are total overkill for games, so both are more than enough, the only thing is that paying extra for an Intel k-version is kinda dumb, because at the performance point of those CPUs, you don't need to overclock anyway, and k-versions are deprived of arguable the most important feature you'll need in the near future, IOMMU. So you could save some money on an Intel CPU and a cheaper mobo that isn't made for overclocking and supports VT-d, like for instance a nice B or H series chipset mobo, which get higher fps than Z series Intel mobos in most games anyway, or you could go for an AMD FX6350 or FX6300 for instance, which is more than enough for best experience gaming with a good GPU, and costs much less than the FX8350 in cooling and mobo (because the FX8320/50/... are power hogs, they require a more expensive mobo for stable overclocking, and they produce a lot of heat, so you'll need a more expensive aftermarket cooler). It's much more important to get a good graphics card for gaming, the CPU doesn't add much to the gaming experience.
Have you considered the FX-6300? It's a great choice for a budget build.
i dont know what your budget is?  For a good advice its allways good to know what kind of budget you are. looking for the best gpu you could afford and build a balanced system arround that. amd is allways a good choice, but like Zoltan allready mentioned, if you dont care about overclocking or tons of feutures, then an i5 non K could be cheaper in some cases.
But i still prefer amd for budget gaming builds.
I own an FX-8320 on an Asus Motherboard with the Hyper212EVO, even with no overclocking when paired with a GTX 760 it does very well in high/ultra and i play at 1080P, if you manage to get a very good chip and maintain a good overclock you will not need anything more for quite a while, also with games starting to use more than 4 cores the 8 core chips will start to shine and maybe even leave the i5 in the dust, i'd recommend an FX8320 or 8350 depending on the price difference
The 8350 will last longer than the i5 because the i5 will start to lack once games get threaded for the 8 cores the 8350 and i7's provide. That's not to say the i5 is slow by any means, it is blazing fast just lacks hyperthreading or 8 cores. You won't see a difference between them for 3-4 years but the 8350 will start to be a bigger benefit. Also am3+ motherboards are cheaper than lga 1150 motherboards.
As others have stated, 8320 or 6300 (8320!). The i5 shines with single-core performance, but on a budget the AMD option is the way to go. Unless...you play a lot of MMOs/Starcraft. Then you really need to go with the intel option - even an i3 over an 8350. That's the extreme case, but worth noting.
AMD has turbo core. It's not hyperthreading, but does the job to if you need less cores.
