ok i am getting i5 (3rd gen ) for lower price then fx 8350 !
so which one should i take cause im my country(india) local shop
i get fx 8350 for 209.54 $
and
i5 3750k for 196.95 $
so which one would u take
and my rig for amd is -
processor - http://www.newegg.com/Product/Product.aspx?Item=N82E16819113284
motherboard - http://www.gigabyte.in/products/product-page.aspx?pid=3908#ov
hard disk - 1tb
vedio - GeForce GTX 650 or GeForce GTX 650 Ti
ram - 1600 mhz (4gb)
is it good ? will it run update to date games
or should i go for i5 ?
suggest me a rig for it =.=
I say that for now you should get a cheaper quad core (such as the AMD Phenom II X4 955 BE) from a website like Amazon or Ebay. That will open up another $100 to buy a better GPU, because the 650 or the 650 Ti will not be able to handle newer games like Crisis 3. A build like this will be plenty for gaming unless you're doing some heavy video work. BTW I would reccomend a HIS Radeon HD 7850 for the GPU. And I'm pretty sure Amazon ships to India.
That's a great price for the 3570K honestly, and as far as CPU's go, it is a great model. I have one myself and it does exceptionally well. If you were to go intel, I'm not quite sure what your pricerange is, and if having an SSD matters much to you so I can't really put something together. Shoot a price point at me and I'll put something together.
i am already getting 650 Ti for 200.88 $ here its very much costly
can u suggest come cheap gpu ?
