FX-8350 vs I7-3770K Benchmarks?
Hey guys, so after I watched Logan's new video, I was just stunned with how low the FPS he was getting was. Is it because these two games are not well optimized? I know Crysis 3 is new so that might be the case with that. However, in the 8350 vs 3570k video, he got way more FPS in FC3 than he did in this new test. I've heard FC3 is awfully optimized as well though. What's the deal here?
I run a 2500k at 4.5ghz with a highly modded GTX 480 running equivelant speed to a 7950, i run FC3 with decent FPS around the 45-60FPS mark with all settings turned up.
Doesn't make sense D:
Crysis 3 still has driver optimizations to go through, so the Average FPS will improve, and probably more so on the AMD side as its in an AMD bundel and that more than likely means AMD optimized (talking about GFX cards mainly), i dont know if you saw but Far Cry 3 Had a lot of problems FPS wise at first before the drivers were updated.
True, I know there were a ton of GPU problems with the Crysis 3 beta. I have heard that FC3 was really badly optimized, but I didn't know how bad until I saw a 690 with a 3770K getting less than 40 frames, thought that had been improved by now. I just find it weird how a stronger GPU (7970) had a lower FPS in FC3 than a weaker GPU (670).
Here is C3 on my 480, on high settings with 4x SMAA i think?
It is not maxed out.
http://www.youtube.com/watch?v=U0hZi3Q-J04
http://www.youtube.com/watch?v=SoiLbZGa044
A good 40+ fps, even at beta stage which was horribly optimized.  I subbed by the way.
Cheers for the sub :)
Yes, do remember this was using software recording, it drops FPS around 5-10fps, so the minimum and average is higher whilst not recording.
Impressive. I still believe this game is badly optimized. Why can't it be like BF3 D:
just give the devs a bit of time and im sure theyll Patch it and well also probably see some driver updates from the card makers aswell, plus its a GFX powerhouse anyway, there so much deatil when maxed that pretty much every GFX card will be breaking quite a sweat.
Hopefully. Far Cry 3 doe, that's been out for a while and I've seen a good amount of driver updates for that game specifically on the AMD side. Why would the FPS be so low with everything maxed on a monster pc (8350, 7970).
Crysis 3 graphics vs any other game on the market dont even come close.
