I recently bought a FX 8350 with an ASUS Sabertooth 990FX R2.0 and H80i cooler.
I am planning on overclocking eventually when all my other upgrades arrive (GPU, PSU, monitor, case etc).
So I thought I'd run a prime95 test at stock (4.0Ghz) and my maximum temp was 55C.
Which I consider to be too high. (At idle I run 29-35C)
Couple of questions:
Is this a normal temp for the FX 8350 at stock? As this is already quite high will I be able to overclock? (I am new to OCing so I wont be looking for more than 4.5ish)
Download AMD Overdrive and see what the temps on that program say. Also, http://www.overclock.net/t/1128821/amd-temp-information-and-guide Is a good Idea on how your temps should come up and what they actually mean.
Also, Tomshardware is so violently anti-AMD most of the time I really do not advise using them for questions on AMD.
Huh, well are you sure the fans are directed the right way? I read through a different thread about the your problem and the guy had his in push/push by mistake and was getting similar temps.
I have checked the fans (before install and when i saw this to double check) and they are correct, i looked at both the airflow shown on the fan and the 'paper test'.
Yeah, I find Tom's to be a mess most of the time, but that CPU can run at 55. It's best to keep it below 60 as that will shorten it's life, but it will not fry at 55.
Oh, I missed that... 55 at stock... Well, we were running at H80 and it was way too loud so we swapped if out for the Xigmatek Dark Knight II. It is running at around 60c at 4.6 Ghz. I am probably going to bring it down to 4.5 and see how that is. 60 is a bit hot for me.
You might be able to oc a little. See what the temps are doing if you raise the frequency. Also, see how far you can go without adding voltage. It won't be munch on the 8350.
if you are seeing a CPU(socket) Temp at that much higher than your core, it sounds like you may have issues with the thermostat on your mother board, OR, you have very poor Airflow in your case and it is dumping hot air into the case without a real exhaust for it.
Yeah I swapped the fans out to SP120s quiet edition so its runs nice now! Yeah I would have to agree with you, I wouldn't like to see 60C come up to be honest.
Ok, I'm not going to be OCing until all my parts-new case, psu, gpu, monitor and ram come (due to my income this may be up to 2-3months)
If im honest my airflow is poor at the moment, i have 2 intakes- front and bottom (and then the radiator on top of them 2) and 1 real exhaust-on top and then 2 exhausts next to the HDD cages, which expell pretty cold air.
Later this month i will be buying a nzxt 410. Then i can have 2 exhaust above my H80i so it should be a lot cooler inside the case.
