FX 8320 stock heatsink ocing
I live in a cold place in Canada, my CPU idle temp is ~25C and load is ~50C. Should I go for a slight OC with the stock heatsink in these temps?
i wouldn’t. if you want a good cheap cooler try the cooler master 212 evo
I personally would not push it to hard if you decide to go with an overclock on a stock cooler, maybe no more than 100-200 MHz.
It would be better if you could get your hands on a better cooling solution than the stock heat sink if you are interested in over clocking. Even something like a hyper 212 would quite a boost in cooling performance and a pretty low price.
All in all, I generally air on the side of caution with stock heat sinks and would recommended buying a better cooling solution if you want to overclock.
You could probably squeeze out a few hundred more mhz at the stock voltage.
Well, you can overclock ok with the stock cooler. It's not the best, though, and the core temps will go very high.
I went with a Hyper 212 EVO, but not primarily because of the heat. More of the stock fan on the heatsink being loud as a turbo jet airliner. I'm sure you know this by now.
Invest a $35 into that EVO, you won't regret it.
