hey im new to the forums here but have been part of the tek syndicate community for about 3 years so i know you guys should know something about my issue im aware my grammer won't be spot on in a rush to type this i really want answers ok so heres my issue and my system specs if u need to know more ask and i'll do my best to answer
Case: zalman z3 plus
Motherboard: ga 78lmt usb3 rev 5.0
CPU: FX 8320
Ram: 8GB crucel 1600Mhz
GPU: XFX R9 380 4GB
PSU: cx600m
Storage: 1TB HDD
Screen Resolution: 1280x1024
AMD Drivers Installed: Crimson Edition 15.12 (newest)
the system is about 3 years old apart from the GPU its a few weeks old now.
the issue is when i play fallout 4 im getting 25fps on any settings with god rays off all that stuff turned off video here : https://www.youtube.com/watch?v=aEb5eGndYCg
Note: someone helped me in YouTube comments i found a fix and spoke about it there but not working anymore the fix was to set windows to high performance in power management this no longer works
i am also getting micro stuttering in GTA V every 6s or so for about the first 4min of the game then its gone but i get massive lag spikes and dips in fps randomly trying to recreate these dips in fps is hard seems to be just random i was also getting a complete crash of the game and shown this error message "err_gfx_d3d_init" was told a fix was to underclock the memory of the gpu to 1000 it worked but i still get the dips and sudden lag spikes at random moments
My thoughts possible bottleneck in my system that i'm missing if there was i would say its my MB or my PSU i dont know how to find out whats causing this most other games i play run fine BO3 zombies only never play MP runs fine just about maxed out also BF4 no issues i think my cpu is hot i use stock heatsink i take the side panel off my pc case it cools it down and it runs silent its not what i want but it works my friend gave me a heatsink but i don't have thermal paste and im to poor i also have no fan connectors left and im using a molex to fan thing to power the 2 top fans of my case i also think my HDD might be on its way out not sure move my pc about a lot in a car do my best to keep it from moving about. about to get a sandisk 120GB ssd for my system soon
*Note forgot to mention i rolled back the drivers all the way back to the last beta we had in november nothing fixed it
Thanks so much for reading this far if you know anything that can help let me know i thank you so much guys !
*Update
ok guys i did some tests i'm not sure what to think i'm to new to this as far as i can see my cpu never throttled i could be wrong when OCCT finished it created a folder full of pics iv uploaded them to my google drive can you guys tell me if you see anything wrong link here: https://goo.gl/xpD2xp
also here is a screenshot i took
*UPDATE
FIXED IT GUYS nothing to do with my systems hardware would you believe me that all i had to do it test it with a different screen ........i borrowed my sister's 22inch 1080p tv just because something was telling me to test it .......and result :) ran fallout 4 on high at 60fps and all other games stopped having issues and as soon as i went back to my original monitor issues came back
Thanks for all your help i got a new heat-sync as well just in case pc is silent now and i dont keep the side panel off any more
