Case Corsair 780T Cpu Amd FX-6300 , Stock Cooling Gpu Amd R9 290 4GB Mobo Gigabyte GA-970A-DS3P Psu Silver Power 650W Ram Kingston DDR3 HyperX 1600MHZ 8GB Ssd Samsung 840 EVO 250 GB Hdd WD Desktop Green 1TB
Is it a good improvement to go with asus z97a and a i5 4690k if i play a lot of arma 3, dayz and csgo? Should i wipe the drive if i go with a new os? Because mine is oem so cant change mb without changing os.
in the games your are mainaly playing, you should get more stable and better minimum fps wenn you go with a 4690K yes.
You basicly dont have to whipe your drive, But i would personaly recommend it. If i´m right you can de-activate your current windows on your machine, and then activate it again after you did the swap and clean installation.
If you're going to buy the Intel CPU and MB outright (about 370USD total) you probably won't see a crazy FPS increase for the money. If there are stability issues with the 6300, then maybe a 8320 or 8350 would be worth looking at so you only replace the CPU and not the MB. The Intel would be worth looking at for programs/games that benefit from better single core performance and lower power consumption. If you're going to change the MB, it'd probably be a lot smoother to just backup your data, wipe the drives and re install the OS.
by good improvement, you just want to get rid of the minimum FPS stuttering?
I mean the i5 vs the 6300 isn't really comparable, the i5 kills it in every bench... and in those particular cpu-bound games, upgrading to an 8320/50 won't solve the problem... it's an expensive upgrade, but if those are your games of choice, an i5 will bring the FPS to balance... I don't think it's worth the money since you have a very functional build... but if the minimum framerate in those particular games annoy you that bad, then that WOULD BE the fix that I'd prescribe...
