Which is better for gaming, a AMD FX 6300 and a AMD R9 270 (not X) or a Intel Core I3 4130 and a AMD R9 270 (not x).
Reply ASAP.
Thanks in advance.
Reply ASAP.
Thanks in advance.
i'd say the fx6300 and r9 270
I'll speak out of personal recommendation. The R9 270 = Radeon HD 7870 . I have the AMD FX 6300+ 7870 and it is an amazing combo for the price I paid. High - Ultra on most games at 1080p. Plus the Fx 6300 with a nice cooler and motherboard is a nice overclocker.
The performance between the two is mostly the same. I would go with the FX 6300 unless you want a mATX or mITX system.
FX6300. you'll make good use of those extra cores in game that are able to use 2+ that and more cores could make it more future proof.
Depending on the games you play... ☺
