FX-6300 or FX-8320
Is it worth the extra $45 to get the 8320
My build that I'm ordering soon
RAM: G.Skill Ares F3-1600C9D-8GAO 8GB (2x4GB) DDR3
GPU: ASUS Radeon R9 270X DirectCU II TOP 2GB
motherboard: ASRock 970 Extreme3 R2 Motherboard
SSD: Samsung 840 Series 120GB SSD Retail Box
storage: Seagate Barracuda 1TB ST1000DM003
PSU: Thermaltake Smart Power 650W 80 Plus Bronze
Case: Corsair Carbide 200R Compact ATX Case
Optical drive: ASUS DRW-24D3ST 24x DVD Writer
OS: Microsoft Windows 8.1 64bit OEM
CPU: depends on what you guys think
Any response would be appreciated. cheers.
6300 is a good CPU for gaming, so you wouldn't be at too much of a loss using the 6300. It's more than capable.
The 8320 is definitely the stronger, more versatile CPU. However, I would advise getting a better motherboard to accommodate a 8xxx chip. Most 970 chipset motherboards do not have sufficient power phases for a power-hungry octacore.
By dropping the SSD, you could make quite a number of changes to your build. An SSD is nice to have, but not totally necessary. You might include the 8320, 990 motherboard, and possibly a higher performing GPU. Though, many AMD GPUs have gone up in price following the crypto-currency boom.
I'm contemplating between two as well. I'm currently leaning toward the 8320 but the lack of good 990fx boards in singapore is a pain in the arse.Don't know if it is advisable to drop to a 970 mobo and get a 6300.
If you can't get a 990fx board, go for the M5A97 Evo R2.0. The Evo part is important.
Thanks berserker I'll stick with the 6300 then. So this motherboard instead? ASUS M5A97 R2.0 Motherboard or is that only for the 8 core 8320?
Also getting this wireless adapter. ASUS PCE-N15 Wireless N PCIe Adaptor
Any thoughts?
thanks so far guys been a great help.
The PCE-N15 is quite a weak adapter in terms of signal strength. I've used it before on some test pcs.
If you can add $25 more get the N600 (I think it's called.) As that will do about 1.5x or more than a laptop wireless adapter.
If you are using internet with high speeds and want to go enthusiast mode, get the AC66 by ASUS. Hope that helped!
Yes thank you Lomyde for your input. I will get that adapter.
Thank you all, you've been a great help, however I'm reaching my limit at $1200, the rest I must spend on a keyboard.
Berserker I like your idea of taking out the SSD for a better gpu, but I'm not making this computer with the soul purpose of gaming (although it would be nice).
ty all!
http://pcpartpicker.com/part/msi-video-card-r78702gd5toc <--- Same GPU... $125 cheaper...
thanks all, it's on the way :D
