i am looking up my computer on Can You Run It and the recommend is fx 8350.
so dos the fx 6300 need to be overclocked to run this game?
Recommended is not minimum requirement. If the FX8350 can run it, the FX6300 certainly will. And the 4xxx CPUs and all manner of legacy components, cheap alternatives like the Athlon.
It's just that the 8350 might be a little more "optimal".
