http://www.newegg.com/Product/Product.aspx?Item=N82E16819113287
vs
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
vs other processors of about the $100 range
vs
They're pretty much neck and neck but the 4300 does a touch better in games and will likely OC higher.
The FX 4300 has higher stock calcualtion speeds along with a larger gap for overclocking! If I were you I'd save the extra 20$ and get the 6300
4300 is better by a little but phenom II is $45 less.
Yeah I don't think the fx 4300 is worth the extra $29 vs the phenom II x4 965
