im planning on building a PC this summer (for the first time) and i would like some feedback on the parts i am thinking about using. i am planning on using the computer throughout college for gaming, programming, 3d modeling, etc and i would like it to last until i have finished college with minimal upgrades. thanks for the feedback.
AMD FX-8350
asus sabertooth 990fx
corsair vengeance 32 GB
Seasonic x-1250 1250W
Corsair hydro series h100i
NZXT Phantom 630
Debating on gpu, storage, optical drive, and cooling options
As zanep, pointed out, the PSU is definitely overkill. Depending on what GPU you get and whether or not you plan on OC'ing you'll be looking at something between 500-750w. RAM also seems excessive; 16GB at 1600MHz+ would be sufficient.
Your budget would be helpful in determining what suggestions and/or revision can/should be made.
