Full-Tower Case Recommendations
The title says it all, I am looking for a full tower case with multiple fans, I have been looking at the Phantom 820, but I don't know if its worth it. Thanks in advance!
Budget?
No budget, eh? Corsair 900D.
$260
What I think you meant, William, is "no budget, Case Labs" ;)
However, $260 won't get you a Case Labs, it'll get you some seriously nice stuff, though.
Personally, I think a used TJ07 is the best way to go. You could buy it, mod it, paint it, and have a really amazing case for watercooling, air cooling, or just wanting an insanely high quality chassis.
However, the Phantom 820 is also a nice case, not nearly on par with the TJ07, but it is really nice.
http://pcpartpicker.com/part/corsair-case-cc800dw
The 800D then. It really depends on if you like the asthetic though. We can't really decide for you; we're not going to have it sitting beside our desks for the next couple years.
I forgot about that one, Brennan.
Case Labs >>>> everything else
That's true, I guess I'll look into your suggestions.
My advice is to look on craigslist i found my silverstone tj10 on craigslist (for $100) and i have seen some tj07's and tj09's on craigslist too.
I personally  have the Cooler Master StormTrooper. As of right now, I have 9 fans in it. 2 bot, 2 side, 2 in front, one up top and 2 in the rear. I originally purchased it so that my 2x550 Ti's would have room to breath. Have the 7970 ghz ed now. Keeps everything where it needs to be. There are some ports for liquid cooling but if you're going heavy with it, another case would be better. Just looked on Amazon and I think the price I saw was $149.99. You can also set up a few different type of fan configurations. Also comes with the SSD adapters for the drive bays. Best wishes!!! :)
I'm getting a Silverstone Raven; it is a bit strannge but the 90 degree mounting allows room for dual 180mm at the bottom or triple 120, single 120 at the back and top, dual 120 at the front and dual 120 on the HHD cages. Sadly it only supports E-ATX and smaller.
