Over the past few months Bf3 has been crashing my PC just as the level loaded and I ended up needing to hit reset in order to get it to work again. It didn't bother me at first since it was pretty rare but this has kept getting worse and worse and now with BF4 I must say it has gotten out of hand. About 1 out of 3 game loads end up crashing my PC right now and with 3-4 minute load times for each level this is very annoying. This is only going on with those two games and no other games or applications affect my pc this way.
My specs are:
CPU: Amd FX 8350 4.0 GHz
GPU: Gigabyte GTX 760 2GB GDDR5 with the latest drivers
Run some memory diagnostics and CPU stability test. Update motherboard drivers as well just in case. Dial back any overclocking, including the graphics card even if it's just "factory overclocked". To see if any of it helps. I've seen factory overclocked cards become unstable before with games that really push them.
I did use memtest.exe for the memory and it didn't come up with any errors, although it did take almost an hour to 100% it and i'm up to date with my mo-bo drivers. I'm not running any OC on my CPU but the GPU is factory overclocked, so I will take it down a notch. By the way, I'm running Windows 8.1, if that might help. What software should I use to test the CPU?
I'd go with the trial version of AIDA64 for some CPU testing. It's good at stress testing all parts of the CPU. But try just the graphics first since it's factory overclocked.
It seems it was the GPU. I've loaded up the game about 25-30 times on stock frequencies and it I didn't have a single crash. I think I'm gonna send it to warranty after the holidays. Thanks for the help! I love this community!
