Front panel connectors
So uhm, I'm building my first pc right now, and my mobo did not come with the white front-panel connector thingy that you can see Logan plugging stuff into around 13:50 on this video:
http://www.youtube.com/watch?v=W4Js2A1qdB8
My mobo didn't come with one, and my case didn't come with one, so I have no idea where I should be looking for it. It'll be ok for me to just plug them straight into the mobo without that white connector thing, right?
 The really strange thing is that the mobo manual says to use an included one, though there was not one included. Kinda confused on this o.O
If your mobo dosent have a usb 3.0 hedder just dont plug it in or use one of these to convert the usb3 on your case to usb 2.0 http://www.amazon.com/USB3-0-Front-towards-USB2-0-Motherboard/dp/B009SJCPO8/ref=sr_1_2?ie=UTF8&qid=1366556030&sr=8-2&keywords=usb+3.0+to+usb2+header
But what mobo do you have?
That literally has nothing to do with my situation. I'm talking about the qConnector that he uses in the video to plug in his power switch, power led, etc. I have the MSI 970A-G46, and the manual says to "use the enclosed mConnectors to simplify installation." There was no mConnector enclosed in the box, so I scratch my head.
O i see ..not all mobos come with a cue Connector you have to place them in there slots if you dont have one like this http://www.youtube.com/watch?v=aE2y30bIejE
Mkay. I have it all connected. Now to just get the PSU hooked up to everything and get these damned cables routed in a way that doesn't make me want to hurt small animals. This case cost $20, and I definitely got what I payed for--very difficult to keep everything looking clean.
