My friend is building a PC soon and I helped him choose parts. I just want to know if what I chose was good.
Motherboard - Asus - M5A97 LE R2.0 AMD
http://www.microcenter.com/product/398235/M5A97_R20_Socket_AM3_ATX_AMD_Motherboard#
CPU/Processor - AMD FX 6350 Black Edition 3.9GHz Six-Core
http://www.microcenter.com/product/414698/FX_6350_Black_Edition_39GHz_Six-Core_Socket_AM3_Boxed_Processor
HDD/Hard Drive/Disk - WD - 1TB 7,200 RPM SATA 3.5" Internal
http://www.microcenter.com/product/425617/1TB_7,200_RPM_SATA_35_Internal...
LAN Adapter - Patriot - Wi-Fi N300 USB Wireless LAN Adapter
http://www.frys.com/product/8126225?site=sr:SEARCH:MAIN_RSLT_PG
DVD Player - LG - 24X Internal DVD ReWritable Drive SATA
http://www.microcenter.com/product/420410/24X_Internal_DVD_ReWritable_Dr...
Video Card - Asus - GeForce GT 640 2048MB DDR3 PCIe 3.0 x16
http://www.microcenter.com/product/397030/GeForce_GT_640_2048MB_DDR3_PCI...
Power Supply - Cooler Master - Elite V2 550 Watt Power Supply
http://www.frys.com/product/7970500?site=sr:SEARCH:MAIN_RSLT_PG
Case - Apevia - X-Sniper X-SNIPER2-BL Black Steel ATX Mid Tower Computer Case w/ Side Window-Blue
http://www.newegg.com/Product/Product.aspx?Item=N82E16811144286
RAM/Memory - Patriot - DDR3 16GB 1866MHz
http://www.frys.com/product/6999697?site=sr:SEARCH:MAIN_RSLT_PG
He's going for $600
Update:
http://www.microcenter.com/product/434028/GeForce_GT_740_Superclocked_2GB_Video_Card
Is that GPU any good?
What about this?
http://www.microcenter.com/product/429625/GeForce_GTX_750_Ti_Overclocked_2048_GDDR5_PCIe_30x16_Video_Card
The motherboard is staying the same but with a FX 6350.
For the ram he said I can have some of it for my build with the same CPU but different motherboard.
He can't order stuff online so that could be a problem.
We are also searching for a PCI WiFi thingy.
