I just installed Windows 10 from a USB stick, and I’m having this issue where Edge doesn’t work, and I’ve seen a bsod, twice over the span of a first two hours after installing (despite Linux running seemingly fine over these last couple of years)… And I was wondering…
Is there a way to make sure Windows unpacked things correctly, is there some kind of package manifest somewhere and/or a tool to easily compare everything file listed in those manifest(s).
Yeah, that’s just the ISO. I haven’t bothered comparing it, I’m assuming whatever is used to compress the data comes with checksums that can be verified during decompression.
Other things I’m contemplating incl disabling c6/c7 and c1e and going with an older build.
Also either my ISP or MS are throttling my wsusoffline downloads, they start off fine (30MB/s +) but then, annoyingly slowdown to 2MB/s. Time to swap wget with aria2. Just mentioning it illustrate my updates are slow
