Specs for system: Intel Pentium G640, H Cupertino H61, 120GB SSD, 32GB usb drive
PF Sense 2.4.4 and formatted with both Rufus and Win32 Disk Imager
All of the hardware is detected in the bios and works functionally, however when installing I am presented with the PF Sense main menu and the booting sequence. However the booting sequence does go past 9 lines. The system completely freezes and I have to manually hold the power button of the system to power it off. The num lock and every other key of the system does not work once it reaches theses this hanging point.
The last 6 lines are presented as such:
Start @ xffffffff803a000 . . .
EFI framebuffer information:
addr, size 0xe0000000, 0x3ff0000
dimensions 800 x 600
stride 800
masks 0x00ff0000, 0x0000f00, 0x000000ff, 0xff000000
